WS1025: Whistler Software
Spitfire8520
Might be slightly less clueless! =)
Colorado
Just purchased a Whistler 1025 Scanner with FM Radio. Would like to find computer software to program for my area.
Whistler does have software for the WS1025 scanner. There are third party software options available. They are:
ARC404
PSREdit100.
Both should have some type of trial period and will eventually need to be purchased. Make sure that you have a supported USB PC/IF cable in order to communicate with the scanner.
You are stuck with there software as Whistler will not release programming protocols for a better software program!!
Only applies to the EZ-Scan supported scanners, which all happen to scanners that support P25 Phase II.
TexasMale
Port Neches, Texas
Spitfire8520
Can you please tell me where I can get third party software for my TX-1??? I was told there is none and will be none..
N8IAA
Fortunately, GA
Spitfire8520
Well, hijacking someone else's thread is no way to get an answer. But I will. There is no other programming software than EZScan for those radios. This has been stated by DonS and multiple others.
Larry
