when i did the signal settings to lower values, i get all 5 bars lit up the whole time, is it better signal or weaker signal?
BAR1=190 BAR2=230 BAR3=260 BAR4=290 BAR5=320 |
Is it Stark County? The Stark Co site on the MARCS trunked system has 17 frequencies. You only need to enter the red control channel and blue alternate frequencies into the site. Ohio MARCS-IP: Multi-Agency Radio Communications Trunking System, Statewide, Ohio - Scanner Frequencies (radioreference.com) What programming software are you using?how about the transmitter setting for certain county, i have 13 different frequencies, whats the best setting on transmitter setting while programming such as one setting would only show 4, other setting would show 13 and last setting would be 0
Looking at MARCS in the database, the Stark County site is not labelled as Simulcast.yes it is stark county, im using PSREdit500 software. im just basically trying to get the best settings on my scanner (ws-1065) all it does is cut in and out, i also got a good antenna, all new stuff, im only like not even 3 miles from the main center
If I'm guessing correctly (based on the map), use the original antenna, directly on the scanner. You might even lay it down flat, instead of vertical.im just north of massillon on 236 by canal fulton
