Whiteman airbase
oldsarge
Olathe, KS
Does anyone have any freqs on whiteman airbase in missouri
I have Whiteman programmed into my scanners but have yet to hear anything. Since it's such a top secret operation, I believe a lot of their stuff is scrambled or secreted away someplace. I visited Whiteman once and only saw one bomber on the tarmac and they were quickly putting it away in it's hanger. Only the Warthogs were out in the open. Good luck on hearing anything but utility type stuff at Whiteman.
Hooligan
Clark County, Nevada
It's easy to hear the B-2s as they're up playing around in the area. I respectfully suggest you don't have the right freqs in your scanner. If you live in the area, you should search the spectrum, instead of assuming there's not going to be much of interest to hear. Obviously, they have some RF comms designed to be difficult to intercept, but on a day to day basis they're often using systems & procedures that don't have a lot of OPSEC/COMSEC value.
nodak1crdet3
Detroit, MI
388.850 is a common A/A for the B-2's.
311.000 Ops
321.000 Ops
364.200 AICC Primary
These freqs are from an old list 1999, from a person in Kansas City MO. Gregg K
His site doesn't work anymore. Maybe he has a new one somewhere?
http:www.kc.net/~skyking/index.html
Here are some freqs that might still be good.
227.800 303rd FS Groundhog Ops.
235.100 AR-112 Primary.
260.200 Various AR secondary freq.
260.250 Truman MOA.
266.200 Whiteman SOF.
282.800 Truman MOA.
283.700 Boat Mountain Radar Scoring Site.
283.900 AR-309 Primary.
291.900 AR-637 Primary.
295.800 AR-318 Primary.
300.100 509th BW A/A.
305.100 Truman MOA discreet.
305.400 Hog MOA.
305.500 AR-330 Primary.
323.800 ACC
327.600 AR-110 Primary.
343.500 AR-016 Primary.
366.300 AR-116 Primary.
381.300 ACC.
cjrjr507
Libby, Montana
Here's some Whiteman freq's I found, don't know if they are good or not, from an old list.
32.35000 MHz Whiteman AFB:442nd FW Air-Air (A-10's)
32.50000 MHz Kansas Army National Guard
34.60000 MHz Whiteman AFB:442nd FW Air-Air (A-10's)
36.50000 MHz Whiteman AFB:442nd FW CP (A-10's)
36.60000 MHz Whiteman AFB:442nd FW Air-Air (A-10's)
36.80000 MHz Whiteman AFB:442nd FW Air-Air (A-10's)
36.90000 MHz Kansas Army National Guard
38.50000 MHz Whiteman AFB:442nd FW Air-Air (A-10's)
40.95000 MHz Whiteman AFB:442nd FW Air-Air (A-10's)
41.00000 MHz Whiteman AFB:National Guard Ops, simplex
41.70000 MHz Kansas Army National Guard Chinook Helicopters
46.70000 MHz National Guard Tactical (#F1)
46.80000 MHz National Guard Common (#F2)
46.85000 MHz Whiteman AFB:442nd FW Air-Air (A-10's)
49.80000 MHz National Guard Tactical (#F4)
49.85000 MHz Whiteman AFB:442nd FW Air-Air (A-10's)
49.90000 MHz National Guard Tactical (#F3)
49.95000 MHz Whiteman AFB:442nd FW Air-Air (A-10's)
118.72500 MHz Whiteman AFB:ATIS
118.72500 MHz Whiteman AFB:pTD
121.75000 MHz Whiteman AFB:Clearance Delivery
125.92500 MHz Whiteman AFB:Departure
127.45000 MHz Whiteman AFB:Approach
128.27500 MHz Whiteman AFB:Ground
132.40000 MHz Whiteman AFB:Tower
135.57500 MHz ARTCC:Sedelia Low (Whiteman airspace)
138.12500 MHz Whiteman AFB:442nd FW CP (A-10s) "flyby control"
138.40000 MHz Whiteman AFB:442nd FW Air-Air (A-10s)
139.80000 MHz Whiteman AFB:442nd FW Air-Air (A-10s)
148.45000 MHz Whiteman AFB:442nd FW Air-Air (A-10s)
148.50000 MHz Whiteman AFB:442nd FW Air-Air (A-10s)
149.10000 MHz Whiteman AFB:442nd FW Air-Air (A-10s)
149.25000 MHz Whiteman AFB:442nd FW Air-Air (A-10s)
149.52500 MHz Whiteman AFB:442nd FW Air-Air (A-10s)
150.45000 MHz Kansas Army National Guard
227.80000 MHz Whiteman AFB:"Groundhog" 442nd FW Command Post (A-10s)/303rd TFS CP
252.52500 MHz Tac -- possibly A-10 related
255.60000 MHz Whiteman AFB:Tower
260.25000 MHz Whiteman AFB:Truman MOA Control
266.20000 MHz Whiteman AFB:509th BW SOF (B-2s)
273.50000 MHz Whiteman AFB:ATIS
275.80000 MHz Whiteman AFB:Ground
282.80000 MHz Whiteman AFB:A-10's working with FAC and practice SAR
284.00000 MHz Whiteman AFB:Approach
286.35000 MHz Whiteman AFB:Arrivals
305.10000 MHz Whiteman AFB:MOA Discreet/Secondary
307.35000 MHz Whiteman AFB:B-2's and T-38's
311.00000 MHz Whiteman AFB:USSTRATCOM Primany (USAF Base CPs)
321.00000 MHz Whiteman AFB:USSTRATCOM Seconday (USAF Base CPs)
323.15000 MHz ARTCC:Sedalia Low (Whiteman airspace)
335.80000 MHz Whiteman AFB:Clearance Delivery
344.60000 MHz Whiteman AFB:Meteorology
354.35000 MHz Whiteman AFB:B-2 doing pattern work
372.20000 MHz Whiteman AFB:pilot to Dispatcher
381.30000 MHz Whiteman AFB:Air Combat Command Primary 509th BW CP (B-2's)
384.40000 MHz Whiteman AFB:MOA Discrete
388.85000 MHz Whiteman AFB:B-2 Freq (Juliet 1)
398.20000 MHz Whiteman AFB:Departure
jsoergel
Cincinnati/Dayton, OH
509th BW presets* from T-38 (594th CTS), circa 2010
[*note: the B-2s have many more presets after these]
01 239.025 ATIS
02 335.800 CLEAR
03 275.800 GRND
04 255.600 TOWER
05 343.650 DEPT
06 323.150 KC 42
07 260.250 MOA
08 286.350 RDR
09 318.050 ACC
10 257.100 SOP
11 321.000 CPS
12 284.000 APP
13 354.350 ARRA
14 359.250 ARRB
15 289.600 ARRC
16 344.600 WXS
17 372.200 P DIS
509th BW:
280.150 Bat Ops/Mojo
318.050 Foxtrot/Maddog/Spirit Control
341.750 tac
388.850 tac
442nd FW:
138.125 Groundhog (Ops/SOF)
138.400 Intraflight 1
139.625 Intraflight 5
139.800 Intraflight 4
149.100 Intraflight 3
149.250 Intraflight 5 (alternate)
149.525 Intraflight 2
227.800 Groundhog (Ops/SOF)
228.575 Intraflight 1
229.175 Intraflight 2
235.125 Intraflight 3
238.575 Intraflight 4
245.250 Intraflight 5
