whoa - a Nextel phone that can do simplex??? r750?
mr_hankey
Helotes, TX
seems like Nextel has been offering a "transition" radio-with-phone for some public works agencies:
http://cgi.ebay.com/ws/eBayISAPI.dl...;item=5713133618&rd=1&ssPageName=WDVW
biggest deal about this model is it can do 1 watt simplex!!!
from the batwing forums:
"The talk-around is set in RSS, and you set it for simplex, or half duplex, iDEN or simple FM. "
has anyone here run across one of these in their day-to-day activities?
ECPD279
Bay Area, CA
I believe those have been around for several years. From back when Nextel was mostly business customers and didn't really cater to the personal side.
N
N_Jay
Guest
Moto-Talk as it is called is new.
I don't know about the FM mode. That may be an RSS setting that was for a feature never developed.
The mode uses spread spectrul digital at 900 MHz in the unlicensed band.
Mozilla
South Florida
Nextel
The original Nextel ruggedized was the R370 also known as the Raven, with external thread on antenna. The radios can work on a isolated site incase of network failure, and do have some additional feature that are not common ... however there are some wild claims which so far have proven to be just that... Type II trunking and simplex operation to name a few. No one has come forward yet with where this option is in the software
( shop level) and what mode and icons are used to indicate this operation.
I have used one of the R370s for 4 years and a R750 for two years.
If someone can come up with where the programming for simplex operation is I will be happy to go to the shop and point it out to them and have them program it. The power company that uses it has never come across these options. They are a great unit...reliable, rugged and the audio is much better and the antenna does make a difference
TN
Isolated Site Operation
The Feature is called Isolated site operation, It works With Dispatch Groups, Not Private ID's. I have not been able to find the operation in the depot rss that the dealership ownes, The feature is also built in to the I90c / I95 and the M470 Mobile.
N
N_Jay
Guest
Re: Isolated Site Operation
Isolated Site is not the same as the talkaround feature that is comming out now.
I don't know what Nextel will call it, but Motorola has anouncecd it as "MotoTalk".
It is spread spectrum in the 900 MHz ISM band. It is digital unit to unit and should have range about the same as FRS/GMRS or a bit better.
I am not sure which models will have the feature, but it is now models, not the old R370 or M470
TN
My Mistake, I should of done a little more research on the post, Off topic but I personally would love to stuff a type II Codeplug into a I95 or I90 That would be a great radio for monitoring!!!!!!!!
