I'm running 2 SDR dongles monitoring an 800mhz system (works just fine).
When I TX FT8 with my HF radio (IC-7300), my SDR dongles lose all reception of the 800mhz system until the HF radio stops tx.
Same behavior goes for 2 regular scanners as well.
The HF tx freq is SO far from 800mhz (40-10m), I don't understand how it could cause this much interference. I have tried TX on the HF radio at 1% power (~1 watt) and still same results.
My HF antenna is an EFHW, feedpoint is 10ft+ away from my scanner antenna (roof mounted discone). My limited understanding is that EFHW can exibit some RF into the shack, but I've mitigated that with grounding and common mode chocke.
What are your thoughts/suggestions?
