Wierd P7100 issue results in 0612 software error
#1
I have two conventional systems in my P7100 and on one of them, if the radio is scanning, it will stop on 2 particular channels then open squelch on and off rapidly for a few seconds,then briefly display SOFTWARE ERR 0614. Afterwards the radio re-boots.
If I try to manually select those two particular channels the radio will quickly try to skip over them. If I quickly delete those two channels from the scan list before the radio tries to skip over them,I can scan that conventional system just fine without any error.
The second conventional system that's programmed in to the radio doesn't result in any error,even though those same two channels are programmed into it.
Could this be a result of a personality error?
