wiki page dead links
digitalanalog
United States of America
from the pages of
wiki.radioreference.com/index.php/Scanner_Antennas
The following links are Dead or Re-Directed:
- Commercial Retailers -
Antennas.US = Cannot be found or is not available
Grove Scanner Antenna page = No Longer In Business
Grove Handheld Scanner Antennas page = No Longer in Business
MFJ Enterprises = Cannot be found or is not available
Kollman Radio Electronics = Redirect to unrelated pop up page
- Coax Suppliers,Filters and other accessories -
- Coax Suppliers -
Jefa Tech = Redirect to unrelated pop up page
sub category under Bizsyscon - LMR-400(50') = Cannot be found or is not available
sub category under Bizsyscon - LMR-400(75') = Cannot be found or is not available
- Filters -
Kollman Radio Electronics Lighting Protection = Dead Link
- Other Accessories -
Full line of Connectors and Adapters = Dead Link (Kollman Radio)
- Preamps/Splitters -
ElectroLine Drop Amps = Cannot be found or is not available
sub category under Electroline Drop Amps - Electroline Installation Instruction sheet = Cannot be found or is not available
sub category under GRE Super Amps - Grove Enterprises also has a page on this amp here = Cannot be found or is not available
Ramsey Wide Band Preamp (via Grove website) = Cannot be found or is not available
- Homebrew, Tech and Reviews -
- Homebrew -
Homebrew Ground Plane = Redirect to unrelated page
Twinlead J-Pole = Should mention this is a Automatic PDF file Download
The Multiband Scanner Antenna = Should mention this is a Automatic PDF file Download
- Other Reviews -
Anthony Haukap's Antenna Challenge = Redirect to unrelated page
SoCal TV Radio's review on mobile antennas = Dead Link
- Technical -
BuxComm J Pole (PDF) = Cannot be found or is not available
- Mobile Antennas -
Comtelco A11855 806-960 Mhz Mobile Antenna PDF = Cannot be found or is not available
- Base Antennas -
Cushcraft Loband Ringos (PDF) = Cannot be found or is not available
Diamond D130J Discone = Cannot be found or is not available
sub category under Diamond D130J Discone- Assembly Drawing = Cannot be found or is not available
Grove Scanner Beam = Cannot be found or is not available
Niljon Super-M Base - Cannot be found or is not available
Rami AS-390A/SRC UHF Milair Antenna - Cannot be found or is not available
All the above items are as marked as of this Date 11/29/2013
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
This is a user maintained area - feel free to edit the page and drop the bad links. Most of the wiki pages are editable by the members and this is one of them. And thanks in advance for cleaning it up
Remember we have over 6000 pages in the wiki - there is a high likelihood that there are dead links on at least some of them. If you notice something is amiss, go ahead and fix it - you don't need to tell anyone nor get permission to do so, as long as it's not one of the very small percentage of pages that are locked.
Mike
digitalanalog
And your point Is?
Well I guess my point was to let it known that the links i listed are dead or not working.
But i guess I wasted my time reviewing all the links and typing all the information.
Well maybe it will be helpful to others, then again maybe not.
If they were my wiki links, I would take care of them, but they are not.
I thought maybe a wiki admin or mod would be happy to know about these Non-Working links.
Sorry.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
My point - you can do this yourself. There is NO ONE here who 'owns' anything in the wiki. It's a community effort, and any member can edit almost any of the pages. The community owns the data, and maintains it. It's a common misconception that the admins, or the original authors, own anything on the wiki and they're the only ones to be able to change it.
Don't worry if you mess something up - we've all done it. A page can be reverted back to its original form pretty simply
11 1/2 hours on the road can make anyone a bit testy, so I apologize if it came off wrong.
Mike
QDP2012
from the pages of
- Coax Suppliers -
- Filters -
- Homebrew -
- Other Reviews -
- Technical -
- Mobile Antennas -
- Base Antennas -
The Wiki page has been updated.
Thanks,
