"Wildcard ID" for Motorola Type II Smartnet?
Warner Robins, Georgia
#1
Can someone tell me what the DEC code/ID for Motorola Type II Smartnet's "Wildcard" is?
Or is it just the "*" symbol, like it is on the P25 Trunking systems?
(I'm not sure if this would be relevant or not but my scanner is a Radio Shack Pro-106.)
Thanks, in advance.
budevans
Cleveland, Ohio
#2
Thanks, in advance.
Are you programming your Pro-106 by hand (directly on the scanner) or with a software package (Win500, PSRedit500, etc..)?
If by hand, go to page 35 in the user manual.
Here's a snapshot of the page.
#3
I usually program with ARC500PRO unless I'm just adding a single item or so.
But, I understand how to program the scanner..
I was just curious if there was a specific "Wildcard" DEC or HEX code or if it was just the default "*" symbol that automatically programs in, like when adding a P25 trunking system.
For example: I read somewhere that "FFF" is the HEX code for a Wildcard for Motorola Type II systems. (But I don't know if that is actually true) And with P25 trunking, the TGID or DEC code that defaults for a Wildcard is just the symbol "*".
Or maybe I'm just putting WAY too much thought into this and over-complicating it. Lol.
Sent from my SM-N920T using Tapatalk
budevans
Cleveland, Ohio
#4
FYI: There are two types of Wildcards. Talk Group Wildcards (TG) which are designated as Group and Radio ID Wildcards (RID) which are designated as Private.
When you create a new entry for a Trunk System, that entry is created as a Group Wildcard. You can then change it to an ID Wildcard or enter a known TG# or RID#.
See an example from Win500.
budevans
Cleveland, Ohio
#5
You're definitely over complicating it.:D
Sorry to hear you are using ARCPro500. Just my opinion. I never liked it.
Win500 and PSRedit500 make things very simple.
#6
I'm beginning to see that. Lol.
I think I might just download WIN500 and try it out.
On ARC500PRO there isn't a column for "Group or Radio ID".. I assume that is what the "Talkgroup ID" column is on ARC500.
Here's how wildcards look on ARC500..
