Will a xts5000 encryption board fit into a APX6000 ?
wsmoore
Jacksonville,Fl.
Will a XTS5000 encryption board fit into a APX6000 ? Also is it true ADP can't be used in p25 Radios anymore? Read a Document on it, but can"t find it anymore so not sure if it was a reliable source.
wsmoore
Jacksonville,Fl.
Here is where I saw the ADP ENC Being banned .
GTR8000
NY/NJ Database Guy
BEE00
ADP no longer comes standard with the APX subscribers, you now have to explicitly order it (although it's still a no-cost option for a single key). This was done in order to ensure that the radios were compliant with P25 CAP standards.
As far as the secure board from an XTS going into an APX...the radios are two completely different designs that share no components. The APX secure hardware is an integrated MACE chip that is either on the VOCON board or the expansion board, depending on the model.
n3obl
ØAES-1024
PA
And to elaborate APX doesnt use an module like the 5000. It has a MACE chip that can support many types of encryption.
wsmoore
Jacksonville,Fl.
But they would still have to order AES Encryption option with the Mace Chip. What's going on is the Local FD has some Enc channels now but they don't have encryption listed as ordered on their APX4500's and APX6000's. So I'm trying to figure out if they will buy some Enc radios and have a cache for the Enc Special Events Tgs and Rescues for the Med Tgs. I was thinking they maybe just going to take the DES boards out of the Police XTS5000's but can't do that. So I guess they lose grant money , go clear on the Tgs,are buy a cache of encrypted Radios. Thanks for the help guys !!!!
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
AES256/DES/ADP can be added in the field....assuming they didn't specifically order them with no encryption.
romanr
Cheese country
That is not correct as of March 5, 2020.
Prior to that date, the default was ADP (for free) and NO ENCRYPTION was an option that had to be specifically called out.
After March 5, NO ENCRYPTION is the default and you must specifically order any form of encryption, including ADP.
The issue is that subscriber units with NO ENCRYPTION must be physically returned to the factory to have any form of encryption added.
For this reason, I suggested that you order subscribers with Q667 (ADD: ADP NON CAP COMPLIANT) since it is a zero dollar addition and it permits you to add AES (or any other encryption algo) in the field.
KevinC
32D2T/957.282
Super Moderator
Actually it's 100% correct. I specified as long as they didn't order them with no encryption.
romanr
Cheese country
I'm not trying to argue whose antenna is bigger, and I did notice that qualifier, but I felt it's important to note that NO ENC is the default now and specific actions (feature inclusions) are now required whereas earlier subscribers almost universally came with encryption support.
KevinC
32D2T/957.282
Super Moderator
10-4. And mines not bigger, it just does it at a higher frequency.
KevinC
32D2T/957.282
Super Moderator
If you see this in your "Feature Set" in CPS you can't easily add any form of encryption in the field. 20200604_084559.jpg
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
What requires the trip back to the factory? Is the MACE IC not populated or the IC is just not programmed/initialized/formatted in a way that a flash upgrade+firmware refresh can change?
