To "enable" a scan list. You would press that number 1 on your key pad to "disable" the same scan list you would press 1 again, or to turn scan list 1 on press 1 to turn it off press 1 again and it will be off. If you press 6 and you see Denver that means you have the correct V-Folder loaded but have the wrong scan list turned on. You can not hear any squelch because you are on a digital system and it does not work the same as a conventional system or frequency.
The scan list for Oklahoma are as Follows.
Scan list City
16. City of Bixby
17. City of Broken Arrow
18. City of Edmonds
19. City of Norman
20. City of Oklahoma City
The way you turn them on is like this. For the number 16. push the FUNC button and then 16 on the key pad same for the others, To turn them off push the FUNC button and then 16 on the key pad.
This is how you "Enable" or "turn on" scan list 11. through 20. twenty being the number 0 on your key pad and by pushing FUNC then the number you wish to turn on. FUNC then 1 is 11, FUNC then 2 is 12, FUNC then 3 is 13. ETC,ETC. FUNC is the Function button.
