Wilmington Control channel
Berlin, NJ
#3
Thanks a lot. I'm trying to pick them up from Pine Hill, NJ. That's a good 20-something miles away, but I think it'll work, even with a rubber 800 antenna.
Berlin, NJ
#5
LOL thanks. Actually I thought Wilmington City was supposed to go onto the Delaware State TRS. Is that still supposed to happen? Also who handles EMS in the city of Wilmington, and where can they be heard?
Six Feet Under
#6
Wilmington's TRS is part of the State System, SysId 583A, Site 4, an IR Site for Wilmington only. There are occasions when WFD TGs are simulcasted to the NCCo Zone for interops.
WFD dispatches BLS or ALS but NCCo Fireboard can dispatch as well.
73
Dave AKA The Tripzter
Wilmington, DE
#7
Ok so the wilmington TRS patch is turned on? Because before the last DB update it always said it was turned off and I had to put all the Wilmington channels in a separate bank. Does this work now?
