WIN 500 question
KidClerk
Newton Co., Indiana
My fire department was just granted coordination for a repeater pair and the output frequency is 151.3625. However, when I add this to my conventional list in Win 500, it rounds it up to 151.365. Is this an issue that needs addressed in the software or am I doing something wrong?
Kyle
What version of Win500 are you using? I just entered in my Win500 without any problems and I'm using V2.0.
K9DAK
Wauconda, IL
On the "Extended Settings" tab . . . check "Enable Flex Step."
Win500 version 1.97.
Ensnared
Waco, Texas
Flex Step
I recently reviewed some of my V-folders & discovered that "enable flex step" was not checked.
Do you recommend checking Flex step as a standard practice?
