Win 98 SE & RadioFeed Issues
I am attempting to broadcast a new feed using Windows 98 SE and RadioFeed 1.13. All is well until I click connect and I get an error message "Set the Input Sound Device to a Valid Input". I have 3 choices, the Primary Sound Capture Device, the ESS AudioDrive, and None. None of these three choices work. Any ideas would be helpful. Thanks.
nexus
Mississippi
Ask your question in email to support@proscan.org or view their Support Page.
This isn't the correct forum section to be asking for software support.
Either use the above or you could go to the wiki: RadioFeed Setup Instructions - The RadioReference Wiki
or go ask in the dedicated RadioFeed thread here:
http://forums.radioreference.com/streaming-broadcasting-audio-recording/201366-new-offering-radiofeed-1-0-a.html
VE5JL
Saskatchewan VE5 Land
You should dump Win98se from a security perspective. It hasn't been updated for a long time and I'm sure there are many security issues with it.
