Win500 and my new PRO-106
vblex
I just bought a PRO-106 for the new digital frequencies in my area. I have downloaded Win500 and imported all of my data.
Problem is when I try to upload to the scanner, it says "Failed - No Response from Scanner."
The instructions with the scanner don't really tell me how to use a programming cable, so maybe I haven't pushed the right combination of buttons??
Appreciate any help.
vblex
OOPS...this new scanner has three ports to plug my cable in. Just noticed that and tried another port and all works well!
al95
Brownsville,Texas
It only has one port for the pc its located at right side of the scanner it also tells you pc/if. The left port is for power and the top port is for external speaker. I glad you did not burned you new scanner, and you got your radio up and running.
