baybum
WIFI most of the time, occasionally via cellular data
And you don't get the keystroke delay problem with either connection, correct?
This is baffling me. Can other users report in and give feedback on this issue?
Thanks,
How do I connect to my "server"? I have everything up and running, but I have absolutely no clue as to what to put for home address or remote address. I know my external static IP address, and my routers 192 address thingy, and the Win500client is showing client: 127.0.0.1. I port forwarded the standard port through my router, but I have no idea where I am forwarding it to, or how to access it. Any help? :-(
And I know my Android app works, because I can connect to a friends scanner online.
Paul
Is that an 11 second AUDIO delay, or 11 second full delay for the entire LCD and audio?
Also, anyone able to advise on post #40?
Paul
It works with Win500Will this app work with a Pro-197 ?
Just to reiterate...this is a keystroke delay issue.
The APP is running for about 10 minutes. When you press a key (let's use WX), you see the scanner react immediately, but the APP takes about 10 seconds to switch to weather.
I wouldn't call it a keystroke delay, at least not the way I see it.
If I hit a key on the Android device, it sends the command to Win500 and the scanner switches to WX.
The keystroke made it without delay.
Several seconds later, the audio and display on the Android "catch up" and reflect the change to WX.
Do you have "compress audio" selected on Win500?
