Win500 display issue with Win7
budevans
Cleveland, Ohio
Since upgrading to Win7 from XP the table header/labels don't show up properly for the following pages.
TSYS objects page:
CONV objects page:
SRCH/SWPR objects page:
Using the TSYS objects page as an example, the bottom quarter of the column header/labels for ( ID, Alpha Tag, Type, Group or Radio ID, Pri, LOut, Delay, Delay Time, Alarm, LED Color, Scan List Man, Hits) is missing.
Some sort of display format or font issue.
Note many many years ago I'd seen a similar issue with Excel and Lotus 123 spread sheet tables when the fonts and row height didn't auto adjust properly.
FYI, I'm using the latest version (1.90) of WIN500.
budevans
Cleveland, Ohio
Tes,
Thanks for the quick reply. The row height was set at 14, I changed it to 16...Problem solved. That was way to easy.
