jimmyo
Anyone having trouble receiving "hit" counts using win500 on a pro106? I have checked enable hit counts but when i download from the scanner no hit counts are shown.
That limit is hard-coded in the scanner's firmware.Apparently the hit counts max out at 10000
I suspected that, except for it being an odd number. Would have expected 65535 at the very least. Thanks, DonThat limit is hard-coded in the scanner's firmware.
Someone might want to tell my 197 it's doing something wrong, I have over 30,000 hit's on 2 different frequencies.
If those hit counts were actually generated in the scanner (as opposed to, say, generated within Win500 in "monitor" mode and then uploaded to the scanner), then yes, your PRO-197 is doing something wrong.
According to the PSR-500 family source code, object (talkgroup, conventional channel, search, etc.) hit counts are only incremented if the current object hit count is less than 10,000.
Interesting...the (from scanner) on the tab certainly looks like your scanner is recording the hits internally, not just Win500 saving them in the active file.
Do you ever use your PRO-197 with Win500 in the program's "monitor / control" mode? If so, hit counts are not limited by the scanner's 10,000 count value. Instead, Win500 will allow the count to go to 65,535. If you then upload that .P500 file to the scanner, the scanner will now have Win500's count.
The scanner itself, though, should never increment the hit count for any scannable object beyond 10,000.
Do you Don, expect the PSR-500, PSR-600, PRO-106 and PRO-197 to all behave in the same manner with regards to hit counts? Thanks
I have all of these models (except the PRO-106 or PSR-410) and run the PSR-310 by far the most. It is on that model (and the '500) that I clearly see the hit counts maxing out at 10,000.(The PSR-310 and PSR-410 might also be included. They're really analog-only versions of the PSR-500/600 and were derived from my PSR-500 source code. However, I wasn't involved in the porting of that source to those new models, so I cannot be completely sure that the hit count feature was/wasn't modified.)
