qlajlu
Silent Key
I decided to take the new version (1.84) of WIN500 for a test drive today and found two things.
First was it is very sluggish loading the data to the software after selecting the Country, State, etc. compared to the previous version. This may be the result of the changes RR made to the Database rather than the software itself, but it is quite noticeable.
Second was a pop-up (see below) that says, "The selected sites appears to be a mix of Default and Splinter 800 MHz frequencies and may not work in a single TSYS." This is NOT correct. UCAN (the system from which I was importing) is THE system for the entire state and the import I attempted was only one site (Site 003 - Salt Lake Simo). The entire state system under UCAN has been rebanded and is not a Splinter mix and no other systems are involved. The Custom Table that WIN500 created (I selected, "Yes" from the pop-up) was not close to the rebanded table now in use in our state. The correct rebanded table is a selection inside the WIN500 software under TSYS > Trunking Tables.
I would think that this warning pop-up should be removed or at least changed to warn that the system/site attempting to be imported has been rebanded and that after importing the data a custom trunking table must be selected from those offered by the software rather than offering to create the table itself.
This warning is very confusing and especially for "Newbies."
