Win500
tonsoffun
Senior Moderator
Moderator
Central Ontario
Hey guys,
Is anyone else having an issue downloading from RR.
I am getting a Soap error comminicating with radioreference.
Soap
A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because the connected host has failed to respond
Connect failed in tcp_connect
tonsoffun
Senior Moderator
Moderator
Central Ontario
A very old one. Update it.
Wrong, newest version (2.02) just installed two nights ago, give me some credit Rob!
Edit: Just tried my ARC500 (Latest version V1.12 Build 6) and its giving RadioRefDisconnected Wait retrieving HTTP data, I must be missing something so simple that I'm not thinking about:confused:
