win96 \ pro2096
ga82832bud
#1
Recently Morgan County changed to p25. So i opened program win96 to do a web import from radio reference. When i open win96 and select web import \ radioreference \ the next screen ask for my logon and password to radio reference. I enter it then i get a null error and it will not logon to radio reference
ga82832bud
#3
Im now a prem member. The error message changed now to this:
there was an error communicating with radioreference.com. the text of the erro was:
No connection could be made because the target machine actively refused it
connect failed in tcp_connect()
buddrousa
NW Tenn
#4
Have you updated to the newest version of the software you are using? I remember a change years ago that had something to do with remote connections to RR.
Kokomo, IN
#5
I have had thar a couple times. To fix it I 1. Shut down computer. 2. Said long string of bad words. 3 restarted computer.
buddrousa
NW Tenn
#8
I just tested win96 V 01.74 an it worked. What OS are you using? Bypass or turn off you anti virus or firewall software. Try a second computer.
