Win96, Win97 now real slow to load
Clark
Venice, Calif
Hadn't used Win96 or Win97 for a couple of months and now both programs are real slow to load, about
8 to 10 minutes to load. Both load perfectly in Vista Windows "Safe" mode. All other programs and computer runs perfectly. Win96 version is 1.71 and Win97 version is 1.34
Reinstalled both programs but it didn't correct the problem.
Clark
Kel
Southwest Florida
My Win500 is the same way after I upgraded to the latest version,I have since went back to Version 1.94 I believe,and now it loads in about 4 seconds,maybe I did something wrong but it worked fine since previous upgrades.
DonS
Franktown, CO
I can't think of any obvious reason why they'd be slow to load. On my Windows XP Pro (SP3) and Windows 7 Ultimate (64-bit) machines, the current versions of all three apps load in less than 2 seconds.
About the only thing I could suggest would be to see if any anti-virus software is somehow "blocking" the apps, or at least causing some strange slowdown in loading.
Clark
Venice, Calif
Win96, Win97 real slow to load
Don, you are correct about ant-virus causing the problem. Disabling Norton Auto Protect and Win96 and Win97 load normally and promptly. Auto Protect can then be enabled and both run perfectly as does everything else.
There must be some kind of a conflict but I have no idea what it is. This slow loading problem wasn't there with earlier versions of Win96 and Win97.
Disabling Norton Anti-virus is just a minor inconvenience and at least a work around.
Thanks for the suggestion.
Clark
Highpockets
Toms River, New Jersey
Clark
Thanks for the info. I just hope this is something that can be corrected in the future.
DonS
Franktown, CO
I don't use Norton, but...
Is there any way you can tell Norton to "ignore" or "allow" a particular executable? It may be that you'd done that before - for earlier versions of the WinXX programs - but now Norton is seeing new versions of the executables for which your prior "ignore" or "allow" is not valid.
Highpockets
I did tell Norton to allow Win500.exe, that at least let me use the program, before that (allow) it wouldn't and put the file in the Quarantine Directory. It's still takes a long time to load, not like before the upgrades, but I can use the program.
Highpockets
I figured I'd re-download and unzip the files over to see if that helped. I noticed when I unziped it I get a warning on the bottom of the screen I never noticed before:
This file does not have a valid digital signature that verifies it's publisher. I never saw that before, or I never took notice of the warning. :confused:
DonS
Franktown, CO
Neither the ZIP files nor any of their contents ever had any "digital signature".
It's starting to sound like either Norton (or, possibly, Windows itself) has been updated.
hiegtx
Dallas, TX
Which version of Norton are you using? Anti-Virus? 360? Internet Security?
I'm using Norton Internet Security 2011, and Win500 v2.01 is loading in 3-4 seconds (Windows XP SP3) on one pc, and slightly faster on my laptop (Vista Home Premium). I have not (so far) had to tell NIS to exclude Win500 or classify as "known safe".
Highpockets
Norton Security Suite is what I'm using, through Comcast.
Kel
Southwest Florida
I also disabled Auto Protect on Norton Internet security 2011,and now it comes up in like 2 seconds compared to 1 minute or more,but now I have no protection,is there any settings somewhere else I can set?
Kel
Southwest Florida
Just a quick update to my previous post it must be Norton 2011,as 2010 version on my other computers work great,I am using Windows XP in them all.
Kel
Southwest Florida
Checked off User Trusted on Norton Insight file for Win500.exe,now things are working perfect,fast and still have internet protection.
Clark
Venice, Calif
Norton Anti-Virus does have a setting "Exclude from Auto-Protect" . I added Win96.exe and Win97.exe
to this list and now everything is loading as it should and Auto-Protect is doing its job on everything else.
I've never used that option before, never thought of it.
Clark
Cryptolog
Colorado
I have the same problem. I have Norton 360 Premier on Windows 7. Downloads and extracts fine. When I try to run win500.exe, Norton SONAR deletes it as a high risk even though Insight says it is trustworthy. If I turn off autoprotect, start win500.exe, then turn autoprotect back on, everythings seems ok. I can't find how to put win500.exe on an "exclude" list. Ideas?
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
My Norton 360 settings in firewall.
Cryptolog
Colorado
The win500.exe rule I made says "allow" instead of "auto" but it works. Win500 still takes about 2 min to start but at least it's not being deleted by Norton. Thanks, fmon.
fmon
Eclipse, Virginia
You bet shipmate and vet. Maybe your Enigma has too many codes to decipher. :lol:
Mine starts in a ms.
