Win96
ga82832bud
#4
almost there, but still have a problem
Im now a prem member. The error message changed now to this:
there was an error communicating with radioreference.com. the text of the erro was:
No connection could be made because the target machine actively refused it
connect failed in tcp_connect()
SteveC0625
Northville, NY (Fulton County)
#5
There's another thread just started today by others who are having the same problem downloading various stuff from RR. Looks like it's now a server problem.
Give it 12 to 24 hours and try again. They usually get these things resolved pretty quick.
blantonl
Founder and CEO
Staff member
Shavano Park, TX
#8
I am not aware of any server problems at the moment. Please check with the software developers on this issue.
Sent from my iPad using Tapatalk
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
#10
The message that says 'the target machine actively refused it' makes me very suspicious. Have you made any changes in your network settings? Using a VPN or other tricks in your router? Sounds like the server at the other end saw an IP packet it didn't like.
Very suspicious...and just a WAG on my part...Mike
