Windows 10 And CPS R06.12.05/9
Polby
Motorola CPS software versions R06.12.05 and R06.12.09 hang up on installation in Windows 10. Initially appears as if setup.exe does not run. However, after many minutes to an hour, the Motorola CPS graphic appears and InstallShield appears showing 100% but freezes at that point. Changing compactibility options has not helped. Any ideas on how to get past this and install CPS on Windows 10?
Using a Microsoft surface pro 5 windows 10 64bit
chief21
Summer - Western NC; Winter - Tampa Bay FL
If you haven't tried to load the application "as an administrator" you could try that, but I've read many reports that most older Motorola CPS applications will run only on 32-bit Windows - and rarely on Windows 10. Also, certain CPS apps will work only with a true serial port. I have an older Windows 7 (32-bit) laptop that I use exclusively for radio programming.
Polby
Thanks I have an older laptop that runs everything. This is an upgrade. I’ve run as administrator and also in comparability mode for win 7 32bit
Polby
After about a week I have figured it out. If the software does not load go to task manager- Details- Scroll down to the setup.exe - right click go to analyaze wait chain and end the process of whatever is in the box. Software will load as normal.
Ant9270
The Green Weenie
I run it on windows 10 32 bit no issue. Another fix you could do is running it in compatibility mode and as an administrator. That usually fixes it
pboyd
I keep a Windows XP VM around to program my old HT radios with an old CPS version. It's probably something along the lines of what @Ant9270 said, i.e. that it doesn't like 64-bit...
