If you use the Zadig that comes with the later versions of SDR#, it will give you the correct driver:But I only have 1 plugged in. Dump1090 Won't work. And if I run FMP24, it will run, but thinks there's 2 devices and that the 1st one is in use. This is causing an issue trying to run stuff. Any ideas how to trouble shoot? Thanks.
Youtuber SignalsEverywhere made a video about this:From time aprox. 50 sec. the solution is showed.
