Windows 7 and CPS/APX
ts548
Anyone having any issues getting CPS and APX software to work on Windows 7 Pro 64-bit? I'm picking up a new laptop and it has 7 Pro 64-bit on it. Both are with in one update of the latest version from MOL.
N1XDS
ÆS Ø
Make sure you have all the updates installed after you installed the CPS software as I had to do when installing the CPS on my father's windows based laptop since I couldn't do it on my Apple Macbook Pro laptop. Once the updates installed on my father's laptop everything worked. Check out Windows update to see if it finds anything while installing the CPS software.
W1JJP
Pittsfield, Ma
My CPS works on my windows 7 setup, but I cannot get the driver for the USB programming cable to install on win 7 though......Thoughts?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Remove any other drivers you might have tried to install for this and throw out the discs that came with the cables.
Then go here: http://www.prolific.com.tw/eng/downloads.asp?ID=31
Follow the instructions to log in as a guest and then download the latest drivers for the Prolific 2303 chip set.
Follow the instructions in the zip file to install the driver. You may have to reboot. Should work fine. I've done this several times with different PC's, and it has always solved the problem.
Remember to determine which Comm Port your cable wants to use and then set it in the CPS.
East_Algoma
ONTARIO
Sounds silly...I keep one PC loaded with Windows XP Professional...just in case I have problems with my Win 7 64 Bit...very often do have a problem , however it vanishes once I fire the CPS or any problem program up on the XP machine...Extra PC cost me 50.00
