WinMDCD Alternative
AM909
Radio/computer geek
SoCal
http://www.antistatic.org just says:
"April 13, 2012
Everything is still broken. Still have plans to re-write WinMDCD before MDC-1200 stops getting used completely."
and there don't appear to be any downloads available. Is there an alternative?
SRSP2282
Alachua County, FL
This is a copy I have backed up from a long time ago... It was the last version released. I havent used it in a long time, but it worked great when I did (I moved to an area that is on a trunked system) Best advice I can give, is to play around with your audio levels if you dont get great decodes. It can be a little finicky until you get the levels from your scanner/sound card tweaked. (Note: The link is only good for 3 days, if there is real interest from other folks I can find another way of sharing it more permanently)
https://spideroak.com/storage/OVPXG...inMDCD10.zip?7377e15896f8883e7bdc00255a465865
Schumi1978
Oshawa, Ontario
SRS, would you be able to repost the software to another link?
