winxxcommon.dll
cjs180
How do you get past this after purchasing WIN-97? I can not install the software onto windows vista?
Thanks,
Chris
rdale
Lansing, MI
Start over, because I'm not sure what you are saying makes sense. Step by step - exactly what are you doing, and exactly where are you getting stuck?
cjs180
There is not a lot to get past, I double click on the .exe file after downloading the zip file of WIN-97 and that message comes up. I researched it and found solutions for the pro-96 and installed those files but that did not work. I am at a loss on what to do. Any help is appreciated.
Thanks, Chris
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Thanks, Chris
You should have 5 files after extraction to Win97 folder. Try Right Click on the exe from that folder then select Run as Admin from the popup menu.
