Whenever you import a TG CSV file it will replace what's there. You can also delete all the TG's in the TG Editor by highlighting all of them and then once deleted, write the TG's back to flash. They'll all be gone.
Thanks, I'll give that a try. I have a whole slew of TGs from DC and Virginia in P25RX that I just want to axe. All I want in there are the ones lcal to me and my day to day work. Until, hopefully, "Zones" are created.
One way to do that is to tag the ones you want as a higher priority and the distant ones as a lower priority. Then you can disable the lower priority when you don't want to listen to them. That essentially uses the priorities as a way to simulate zones.
