JohnnyGalaga said:
Where do you get software like that and how do you hook it up to the fone?
Probably from the same places you get Motorola RSS and CPS. It works with the phone's regular data cable.
How do you learn what all those numbers and codes mean on the screan and software?
I guess you could ask on the right forums. howardforums.com or batlabs would be a good start.
From the first photo:
28.79 = SQE (signal quality estimate); It's based on RSSI and BER. Good numbers on that handset would be about 25 to 32. When it gets into the low 20's, the audio is crap.
0EB = current site control channel frequency index.
2 = color code used by current site. Color codes are used to differentiate sites that use the same carrier frequencies.
-00db = handset TX cutback. 0 = no cutback (e.g. full TX power). TX power is controlled by the control channel received signal strength; stronger control channel = less TX power needed to talk back to the site.
-91 = control channel signal strength. -90 isn't very good; -75 would be nice.
0 = TX timing advance. As you move away from a site, the handset has to send its inbound digital packets earlier in order to avoid walking over the user assigned to the next 15 ms time slot. IIRC, 0 = 0 to 5 miles from site, 1 = 5 to 10 miles from site, etc. Those numbers might be off a bit, but the granularity is somewhere between 5 and 8 miles.
+2 = PA temperature (Celsius); yes, it was cold out.
+0 = PA temperature change in last two seconds.
0 = TX power cutback due to PA overtemp. 0 = no cutback, 1 = 16% cutback, 2 = 33% cutback, 3 = 50% cutback.
From the second photo:
SU Link = subscriber unit (handset) serial data link. Green = serial data being received.
GPS Link = external GPS receiver connected to a second PC serial port. Red = no link.
GPS Track = GPS receiver 2D or 3D fix. Red = no fix.
GPS data is used in conjunction with RSSI and SQE readings to facilitate the creation of drive test based coverage maps and lists of dead spots.
CC/Carr = color code and control channel frequency index.
RSSI = control channel signal strength.
C/I = SQE.
SRVR = serving site (the current site).
FGxx = neighbour site with acceptable RSSI and BER. If the current control channel signal degrades sufficiently, the handset will switch to one of these neighbour sites.
BGxx = neighbour site with poor RSSI and/or BER. The handset does not want to register on any of these sites. Five of these sites are in the current site's neighbour list, but the handset cannot detect their control channel RF carriers. This is not unusual, since neighbour lists should not only list a site's immediate neighbours, but also the next ring of sites. This lets the handset find a distant neighbour site when an immediate neighbour site fails or is down for maintenance.
The handset continually monitors the SQE of the serving site and all neighbour sites and will try to use whichever site has the best SQE.
