shammy
What website can I goto to download Wires-x software to my PC with windows 10.
Wires-X, yes I have the answer and it has nothing to do with updating Windows 10.Thank you for the response. I went into the menu and corrected the problem. I was not transmitting the tone because I had the wrong setting. However I do need some advice with Wires-X. I want to download the software for to my windows 10 computer and there are so many sites. Do you recommend any site in particular. It seems I keep go to sites that want me to update my windows 10 but it is uptodate. Shammy
Well I went to download the driver for Windows 10 and there is none. MarkWires-X, yes I have the answer and it has nothing to do with updating Windows 10.
1. You need to register for a Wires-X account. Go to the following URL and fill out the information. I believe you will immediately receive an email from Yaesu after you complete it. You can then login to the Wires-X site. WIRES-X Member Registration
2. In order to get onto Wires-X using your 400XDR you will then need to register your unique radio ID. After you perform step #1 above, login to the Wires-X site with the username & password you provided and along the left it might say something like "Register your node". I honestly forget if this is part of Step #1 or if you need to do this later. It's so easy I just forgot. Still, you will need to register your unique radio ID. That is a definite in order for it to be a node on the network.
How to find your radio ID:
A. Hold down the DISP button until the menu appears (Not a quick press)
B. Select "GM" in the menu window
C. Selection #3 is your Radio ID
5. Now that you have your Radio ID you can fill out the registration so that your 400XDR can get onto wires-X directly as a node. After you submit your information and radio ID, it will take one to two business days until it is approved. This part is not immediate. The email you immediately receive from Yaesu is just telling you they received your request.
6. At this point you must first ensure your computer has the drivers installed for the SCU-20 cable that came with your radio before you plug it into your computer. SCU-20 PC Connection Cable Driver
They even have a manual on what to do if you need it. SCU-20 Driver Installation Manual
7. You should then ensure your 400XDR has the latest firmware. The instructions are in the zip file on how to update it.
FTM-400XDR/DE WiRES-X Portable Node Station Function (FTM-400XD_USA_Firmware_Update_0205.zip) 2/13/19
*** You should now wait until you receive the email from Yaesu giving you your Node and Room ID numbers. You'll need those in order to initially fire up the Wires-X software with your radio connected.
6. After you connect the cable to the radio and computer, you should put your 400XDR into PDN mode. With the radio turned off, hold down the DX button and press the power button. Once it starts let go of the buttons. You need to do this so that during the software setup screen of Wires-X in the next step, it will read your unique radio ID and auto-populate it where it says serial number on the Wires-X program. (You do this once and then you're golden) It says serial number there because this was originally for the HRI-200 serial number. If your radio ID is not automatically filled in, your computer is not reading it. You cannot manually enter that in. That is going to be a driver issue at that point, either not installed or the wrong port selected.
7. Now we finally come to the Wires-X software part of your request. If you are still logged into the Wires-X site great, if not log back in and select "Node Owners Page" on the left. WIRES-X
8. On this page download the Wires-x PC software version 1.510. (Please note that when it goes to install, it will ask if you want Wires-X to start automatically. I personally do not have it auto start on my computers where I run a personal node, like you are about to do. That setting request is a hold over for the HRI-200 device when used on a computer with a dedicated repeater connected to it. The choice is yours of course.
9. Okay, at this point you should also download the PDF on that same page that says Wires-X Portable Digital Node Instruction Manual ( You really need to keep this handy until you memorize the buttons you'll hit to enable the radio as a Wires-X node. You do it again to take it out of Wires-X mode as well. )
I could be wrong on all of this, but it's probably correct. Others may stumble onto this thread as well so I hope it helps.
Answering your questions reinforces my memory or steers me to figure out what I do not know. Besides, your questions are similar to what I myself had and others may have as well. Forums for sharing specific information is one of the greatest things about the Internet.I have requested some assistance from Yaseu to give you a break. mark
