Wiring an HMN3596a (gm300 mic) to work on a spectra high power
So Cali
#2
"Anyone know how to do it?" Yes I use a Spectra/Syntor mic cable.
Hang on Sir, I will get some info for that to you.
Use Spectra mic cable, same colors but White is not used.
PM and I can email details, just have to get old sketch to something others can read.
So Cali
#4
I remember the Desktrac, and I did send the photos of the modded board and cable.
And I was going to sell or trade the Desktrac without the radios.
And I need to finish alignment and calibration on a new two meter repeater today.
Texas
#7
Reminds me, I need to find a mic cable to upgrade a desk mic from a RJ45 to Spectra (either that or go through the rear accessory connector).
Orange County, CA
#12
Thank you! Google wasn't much help in this case, so I appreciate it. The wiring that cmdrwill pulled off google images was incorrect. Locked the radio in transmit. He was right about the tinsel wires...pain in the *** to work with.
So I take it since I don't have an astro spectra, the black wire is not used? Or do I just tie it together with the white wire?
So Cali
#13
The photo I posted is is one of my mics that I took to show the wiring. Not from Google, Sir.
Looks like you have a different mic board. Not like the GM300 mics I have.
Sonoma, CA
#14
Since the GM300 mic has the single ground, connect the black wire and let the white wire hang in the breeze as cmdwill mentioned.
