WiSP DDE client issue
F1TJJ
Hi all,
I'm trying to control my AR5000 and my FT-736 for sat opeartion.
I'm using Orbitron to track sats and WispDDE Client (version 4.2 and 4.3) to control the transceivers.
I do not understand but when setting Wisp with two transceivers, the communication with tem seems to not work and irrelevant information are sent.
For instance :
Transceiver 1 is FT736 on COM1
Transceiver 2 is AR5000 on COM2
Then when setting uplink and downlink on transceiver 1 , then my FT736 isn't controlled and my AR5000 is controlled with some irrelevant frequencies...
It seems this is a COM ports issue..
Does anyone had this question raised before ??
Many thanks
Stephane, F1TJJ
K4NRG
Did you try the AMSAT board to post your question?
