Thanks for the reply. And thank you for the link for SLC, UT. I can't find anything for the cities around slc like West Jordan, West valley, Sandy and midvale. How do I check to see if these cities are analog or digital?
No problem. As W8RMH said it may do you better to ask about specific cities/locations near you in the Utah forum where people know the area. I'm in North Carolina but responded since you posted in the Uniden sub-forum.
Here's a little step by step on how to find what you're looking for in the database :
1 - Click the Database tab at the top of the forums
2 - A map of the U.S. will pop up. Click on a state, in your case Utah
3 - Once you click on Utah (or whatever) a map of the state will pop up with
all the counties outlined.
4 - Click on the correct county.
5 - The first thing that will pop up is all of the VHF & UHF license and frequency info
for public safety/local government agencies in the county.
6 - If that particular county uses a trunked radio system then you'll want to scroll all
way to the bottom of the page and there you'll find a listing of all TRS's being
operated within that county.
7 - Click on the name of the system you want information for.
8 - The next page will display all the info for the system including frequencies and all the
talkgroup (aka TG) information. The control channel frequency is in red, and alternate
control channel frequencies are in blue. The only frequencies you need to put in using
either the 346 or 396XT are the CC frequencies.
9 - The TGID's (Talk group ID) that you will enter when programming the scanner are listed
under the label DEC. Two columns to the right of DEC you will see a column that says
mode. A=Analog , D=Digital , E=Encrypted
Hopefully that'll help you know where to find the info you're looking for and give you a place to start. And I hope I didn't loose you there, lol. But as suggested be sure to post in the Utah forum asking for help on monitoring systems specific to that area. That's what those sub forums are for.
If you've got anymore questions please feel free to ask !!!
