WNC Aero Firefighting Freqs
#1
noticed this the other day and it finally dawned on me someone who is closer might be interested. I can't post a direct link so the relevant NOTAMs are below.
120.025
122.375
122.425
are all designated for various fires in WNC.
!FDC 6/4269 ZTL NC..AIRSPACE 12 NM NW OF FRANKLIN, NC..TEMPORARY FLIGHT RESTRICTIONS WI AN AREA DEFINED AS 3 NM RADIUS OF 351646N/0833354W (HARRIS VORTAC HRS041026.5) SFC-8000FT . TO PROVIDE A SAFE ENVIRONMENT FOR FIRE FIGHTING AIRCRAFT OPERATIONS. PURSUANT TO 14 CFR SECTION 91.137(A)(2) TEMPORARY FLIGHT RESTRICTIONS ARE IN EFFECT. USFS, NANTAHALA NATIONAL FOREST, NORTH CAROLINA INTERAGENCY DISPATCH CENTER, TELEPHONE 828-777-2075 OR FREQ 120.0250/THE TELLICO FIRE IS IN CHARGE OF THE OPERATION. ATLANTA /ZTL/ ARTCC TELEPHONE 770-210-7622 IS THE FAA COORDINATION FACILITY. EFFECTIVE 1611081100 UTC UNTIL 1612090001 UTC. 1611081100-1612090001EST
!FDC 6/3512 ZTL NC..AIRSPACE 3 NM SOUTHEAST OF TAPOCO, NC..TEMPORARY FLIGHT RESTRICTIONS WI AN AREA DEFINED AS 3 NM RADIUS OF 352339N/0835454W (HARRIS VORTAC HRS000027.0) SFC-7500FT . TO PROVIDE A SAFE ENVIRONMENT FOR FIRE FIGHTING AVIATION OPERATIONS. PURSUANT TO 14 CFR SECTION 91.137(A)(2) TEMPORARY FLIGHT RESTRICTIONS ARE IN EFFECT. US FOREST SERVICE TELEPHONE 828-777-2075 OR FREQ 122.375/MAPLE SPRINGS FIRE IS IN CHARGE OF THE OPERATION. ATLANTA /ZTL/ ARTCC TELEPHONE 770-210-7622 IS THE FAA COORDINATION FACILITY. 1611051930-1611202359
!FDC 6/2807 ZTL NC..AIRSPACE 8NM SOUTHWEST OF FRANKLIN (1A5), NC..TEMPORARY FLIGHT RESTRICTIONS WI AN AREA DEFINED AS 3NM RADIUS OF 350730N0833030W (HARRIS VORTAC HRS061022.8) SFC-8000FT TO PROVIDE A SAFE ENVIRONMENT FOR FIRE FIGHTING AVIATION OPERATIONS. PURSUANT TO 14 CFR SECTION 91.137(A)(2) TEMPORARY FLIGHT RESTRICTIONS ARE IN EFFECT. US FOREST SERVICE TELEPHONE 828-777-2075 OR FREQ 122.425/KNOB FIRE IS IN CHARGE OF THE OPERATION. ZTL IS THE FAA COORDINATION FACILITY. DLY 1000-0100 1611041000-1611200100
!FDC 6/2796 ZTL NC..AIRSPACE 20 NM SOUTHWEST OF FRANKLIN (1A5), NC..TEMPORARY FLIGHT RESTRICTIONS WI AN AREA DEFINED AS 5 NM RADIUS OF 350331N0833913W (HARRIS VORTAC HRS062014.7) SFC-8000FT. TO PROVIDE A SAFE ENVIRONMENT FOR FIRE FIGHTING. PURSUANT TO 14 CFR SECTION 91.137(A)(2) TEMPORARY FLIGHT RESTRICTIONS ARE IN EFFECT. US FOREST SERVICE TELEPHONE 828-777-2075 OR FREQ 122.425/BOTELER FIRE IS IN CHARGE OF THE OPERATION. ATLANTA /ZTL/ ARTCC IS THE FAA COORDINATION FACILITY. DLY 1000-0100 1611041000-1611200100
