Ask 100 different people and you'll get 100 different answers. Here's mine!
Go for it.
What if you move your antenna away from your own house (which may be very quiet in terms of RF noise) and closer to a neighbor who might have all kinds of noisy appliances? You'd have a tuff time tracking down his noisy junk and getting him to change it.
Try it with the 9:1 balun, and without ... see which is better in real life. I'm guessing that you're not going to need it.
Any antenna less than 30 ft off the ground on HF is going to be pretty much omni-directional below, say, 10mhz. Too much interaction from the ground. Even so, if the wire is more than 1/2 wave long for whatever frequency you're listening to at the time, you're going to have lobes of best reception is all sorts of weird directions, so although you point you wire in a certain way hoping to peak the signals from a certain part of the world, only time testing it will determine if you're correct or not. As you change bands, the lobes will be different. (unless you've got a rhombic or something like that).
Any sloping of the wire towards the horizon is going to lower the angle of attack and improve it for DX.
So, I agree, put it up and try it. If you're not happy, then take it down and try something else. Even better, have more than one antenna, then you can switch between them to find the best performer at the time.
