Won't connect to PC
yorkphotog
Toronto, ON, Canada
Any tips for a G4 that charges fine, but won't connect to the PC for sync/upgrade purposes? I've swapped out the cables and have done a hard reset of the pager. The PC doesn't make the "hardware connected" sound and PPS does not recognize the radio at all. Thanks!
Try downloading and re-installing driver, make sure the pager is on when you are trying to connect. What operating system (PC) are you trying to connect to, what PPS and Firmware version are you using?
All this helps us help you.
yorkphotog
Toronto, ON, Canada
Already tried re-installing the drivers... Also worth noting I have several G4/G5's with me and they're all connecting fine, except for this one G4. It's got V0.93-0.17K-R02 currently and I'm trying to update it.
Check these threads
