Wood County Ohio SO Frequencies DMR?
Greg43545
NW Ohio
I've had 151.115 programmed into my BCD325P2 and haven't heard a peep from Wood Co., is anybody else copying them?
ctpd845
Martin, Ohio
The analog rebroadcast on 151.115 is not very strong. I can barely pick it up in Perrysburg with a handheld scanner so I doubt you will be able to monitor it from Napoleon without a decent outdoor antenna. If you want to monitor Wood County SO your best bet is to get the DMR upgrade for your BCD325P2 and monitor them on 154.7250.
Greg43545
NW Ohio
You think I should be able to monitor it on my handheld once I'm mobile inside Wood Co./Bowling Green area then?
And if so, does both Wood Co. S.O. and BGPD come across the same freq. of 151.115?
ctpd845
Martin, Ohio
It should work within the BG area, unless they don't simulcast on that frequency anymore. It has been at least 6 months since I have monitored 151.115. Also, that simulcast is only for the SO, BG does not do an analog simulcast.
Greg43545
NW Ohio
HCSO96, Thatsclear said: " I can no longer hear Wood County SO on 154.725 "
You can receive DMR, I don't believe Thatsclear can, that's why I recommended 151.115 to him.
ctpd845
Martin, Ohio
I brought my scanner with me today and was able to hear Wood County SO on the analog simulcast 151.115 from Perrysburg.
Greg43545
NW Ohio
I was on the road yesterday, travelling Northbound on I-75, near Bowling Green, and heard Wood Co. SO on 151.115.
It wasn't the strongest of signals, but I was able to make out their traffic.
Thatsclear
I can't hear 154.725 anymore with 8700 TG slot 1 and colour code 8. Have they went to that RAS mode? or did the parameters change?
Greg43545
NW Ohio
I was in Bowling Green today between 0900 and 0930 hours and heard Wood County S.O. traffic on 154.725.
