Wood-Ridge PD
Rutherford, NJ
#1
Hey gang!
I'm not sure who to contact or how to properly contact an admin about updating the database. It appears that Wood-Ridge (Bergen County NJ) PD changed their PL from 173.8 to DPL 205. I did a tone search to find them while they were assisting the FD at a call. I saw the strength meter was pinning, but had -0- audio on PL 173.8. I found them on D205. This must have happened very recently. Also under Wood-Ridge, you can remove the text that says "See Hasbrouck Heights for fireground channel" since they are on their own FG channel now.
Bob K
#3
In the meantime, would you mind sharing with us what the new fireground frequency/tone is? The database shows dispatch, ops, and mutual aid channels but no fireground channels.
