Could i pick up Woodstock pd with this
BCD-996XT 6000 Channel Uniden Mobile Trunking Scanner with GPS Support and APCO-25
OPTIONAL ACCESSORIES LIST AT THE BOTTOM OF THIS PAGE:
The Uniden Bearcat BCD996XT is a state-of-the-art scanner radio with Trunk Tracker IV™ and automatic scanning capabilities. You can store in the dynamic memory conventional frequencies such as police, fire/emergency, marine, air, amateur, and other communications.You can store and scan services that use Trunked Radio Systems and so much more. You can use the scanner’s Scroll Control to quickly select channels and frequencies and you can automatically program channels in a system using the Auto Store feature. The high resolution display indicates the radio's status in detail.
The GPS-enabled feature offered by the BCD996XT provides automatic system selection, which permits the scanner to turn system reception on or off depending on the user’s location, and allows the user to define the scanner display to show location-based information. In addition, when a GPS unit, not included with this scanner, is connected to the BCD996T, it will alert at areas of special interest, such as dangerous intersections, school zones, or general points of interest. The BCD996T also offers APCO 25 digital capability, allowing consumers to monitor the activities and signals of city and government service departments, and features advanced scanner technology in an in-dash or mobile mount design.
The Bearcat BCD996T also offers Close Call™ RF Capture Technology, Dynamic Memory Management, Fire Tone-Out, and Multi-site programming as well as 25,000 channels and a frequency range of 25 MHz to 1.3 GHz (excluding cellular and UHF TV frequencies). Other recent enhancements include band scope function (.2 to 500 MHz), multi-color display backlit, NAC decoding, Key safe mode and channel alert (tones and backlight color).
FEATURES:
•TrunkTracker IV (Motorola APCO 25 Digital, Motorola, EDACS, LTR)
•25000 Dynamically Allocated Channels
•Close Call™ RF Capture Technology - Instantly tunes to signals from nearby transmitters
•Location-Based Scanning
•Fire Tone-Out
•Multi-Colored Display Backlight
•Alpha Tagging
•100 Quick Key System Access
•Band Scope - Graphically finds radio activity
•Continuous Band Coverage* - 25MHz to 1.3GHz Excluding UHF TV and Cellular
•Audio AGC
•Automatic Digital Threshold Adjustment
•Temporary Lockout
•Search with Scan
•NAC Decoding - for conventional P25 channels
•DCS/CTCSS Rapid Decode - Instantly Detects and Displays the Subaudible Tone So You Can Quickly Determine the System Settings.
•S.A.M.E. Weather Alert - Specific Area Message Encoding - During a NOAA Weather or Emergency Alert, a code for your specific location will alert you to severe conditions in your immediate area.
•PC Programming/Control
•Public Safety Scanner
•System / Channel Number Tagging - provides rapid access to a specific system or channel
•Individual Channel Volume Offset
•Priority ID Scan on trunked systems
What's in the Package:
•AD1009 AC adapter
•Cigarette lighter adapter power cord
•Mobile mounting bracket
•DIN-E sleeve
•Telescopic antenna
•PC DB9 serial cable
•Owner's Manual on CD.
4%
Details
SKU BCD996XT
Weight 5.00 lbs
Price: $699.95
Options
