Wouxun Wouxun KG-UV9D Plus accepting programming cable, but...
Dvr77dan
Hurricane
Hello,
Using Chirp, and the programming cable all works great. Uploading to the radio shows on the radio, and then it restarts as it should. However, the radio only has the two channels I programmed in manually before programming with the cable. I can download from radio and all the channels I programmed in Chirp are there. It just doesn't show up no the radio. What step did I miss?
Please advise.
Thank you for your time,
Dan
robertmac
It may not apply to the KG-UV9D, but some radios need all channels to be associated with a zone for them to appear in the display.
I don't think the UV9D is a digital radio using zones or tags.
