WQDX703 Gilmore location setup JeffCo trunked
#1
I'm using a Uniden BCD396T and I'm having trouble programming the Gilmore location correctly on the JeffCo trunked system.
I'm not hearing all the traffic I should be for that location as determined by listening to other locations simultaneously with another scanner and another location. Only TGID I've seen on it is 500-0 when programmed like the other locations. I've heard partial traffic for Forestdale and Bessemer/River but not complete.
Any suggestions or new information will be appreciated.
#2
The frequency list for Gilmore on the Radioreference.com page is incomplete. I'm hearing traffic now since I used the FCC license info to program all the frequencies for the location.
Taxachusetts
#3
Did you make the submission update ??
Data only get's updated when users like you take the time to
a. Find the Errors
and
b. Most important - make the submission from the RRDB Page
Look for the tab on the DB Page that says "SUBMIT"
