BCD536HP: Write to scanner issue
737mech
Clark County, NV.
#1
I may have missed something? I modified my favorites lists in Sentinel then selected write to scanner. Only a few lists now appear on the scanner when I select lists to monitor? I did select the box to erase favorites on scanner. Why didn't all 15 favorites lists load into scanner?
fxdscon
#2
Check your profile settings in Sentinel to be sure "Download" and "Monitor" are both set to "ON" for all of your favorites lists before writing to the scanner.
