WS 1088
So. Middle TN
#1
I just purchased a WS 1088 and the signal strength icon does not display -- it just shows "S" but displays no signal strength bars on even strong stations. Anyone know what the problem might be and how to fix it?
#3
fix
Go to settings and reset to default values.Fixed.
its in Global settings.
Doesnt work,rehit the scanner with the firmware using Ezscan.
