Ws1080/psr800 -> ws1088?
kh11
#1
Having replaced the control head on my WS1095 to make it effectively a 1098, I'm wondering if a similar swap could be made on the handheld equivalents (assuming that Whistler would sell just the front panel).
#2
Interesting idea! Does anyone know if the front panel assembly from the PSR-800 is the same as the WS1080 (same connectors, size, etc.)?
kh11
#3
I just looked at a PSR800 front panel that I have. Turns out the controls aren't actually part of the panel, it just has the speaker. Though I suppose a "daughterboard" swap might be a possibility.
