WS1098 help
KG5AQK
Mcgregor,Tx
I have just purchased a whistler WS1098 and i must say that i'm pretty lost in programming it i would like to know the best place to find out how to set it up for my local area which is in Central Tx?
stephenf
texas
download ez scan software from Whistler website and then use radioreference in the ezscan menu to upload frequencies to your scanner
wb5nbq
I am in central Texas too, have had WS1098 for a few months. Mark's Scanners has easy to read manual. Download ez scan from Whistler, it's pretty easy to use. Not sure what county you are in, I suggest using Library Import, select import type, "use preferred" let you pick specific items if you don't want everything, also you can set it up the way you want it.
KG5AQK
Mcgregor,Tx
I have the ezscan and i'm a little confused on using it i need to factory reset the unit because it came programmed for Colorado i just cant figure out how to reset everything i set the location by zip and i'm hearing some of my local stuff i am in Mclennan Co.
iMONITOR
Silent Key
S.E. Michigan
The radio comes with the Radio Reference database installed for the whole entire U.S. Use the menu built into the radio, chose your zip code, and radius for the area you want to monitor and you're done! This should all be covered in one page, maybe two of your user manual. It really doesn't get any easier than that.
KG5AQK
Mcgregor,Tx
I have done that i just need to know how to factory reset the unit to get rid of all the previous owners stuff also when i connect it to my pc in windows 10 it says there is a problem with the drive and asks me to scan and repair it is this normal?
troymail
Silent Key
Couple of things --
There really isn't the notion of a "factory reset". The closest thing to that requires using the EZ Scan software to reformat/prepare the SD card for use in the radio.
Using Location Setting options on the radio, you can clear the current configuration to start (somewhat) fresh with programming. We'll come back to that later.
You'll really want/need to take a step back and experiment with and learn the EZ Scan software for lots of reasons. The primary reasons include:
  • making sure you have the most recent EZ Scan software installed
  • making sure you have the most current firmware (CPU and DSP) installed
  • making sure you have downloaded the most current library/database
  • making sure you have transferred that current library to the SD card for the radio to use in your programming
  • preparing your SD card ("reset")
EZ Scan overall will just make it easier to program your radio and save a copy of that programming. It also makes it much easier to visualize what you have programmed.
I strongly recommend that you put the radio down and just spend time learning the EZ Scan software. You'll be a much happier user in the long run if you do.
Now, to do a "reset" (sort of) and give you something to listen to while you learn EZ Scan, here are a few steps to follow:
  1. Power On...
  2. Press MENU
  3. Scroll to Program Menu
  4. Press SEL
  5. Press SEL again to select Global Settings
  6. Scroll UP until you see Location Select (should only take a single UP key to see it)
  7. Make sure that option is checked (Press SEL if necessary)
  8. Press MENU to be prompted to save your settings
  9. Press SEL to save the settings
  10. Press MENU to return to the Main Menu
  11. Scroll down to Set Location
  12. Press SEL
  13. Scroll down to Clear Channels
  14. Press SEL
  15. Press SEL again to confirm erase of current data
The current configuration is now EMPTY.
From the menu displayed, choose your import option(s)
Now - please go back and start learning EZ Scan! Stick to basic programming with the library for a while. Don't spend alot of time initially trying to create any fancy custom programming. That way, there is nothing you cannot recover from.
Ask questions. We're all here to help.
KG5AQK
Mcgregor,Tx
Awesome info thank you sir most of everything on the top list i have done except the prepare SD card i have done the optimize im really wondering why i get the error when i connect to pc about the drive having problems. and again Thank you for the help!
KG5AQK
Mcgregor,Tx
Why when i use ezscan to program the scannerdoes not want to work at all it says updating firmware then errors out if i rewrite the old program to it it comes on fine what am i missing?
