WSP D6 Kittitas
SkyOtaku
#1
It looks like WSP D6 out of Ellensburg has gone Digital. I have submitted it to the database. The digital signal is a MASSIVE improvement over the analog one. I live 11 miles south of exit 206 on I90 and I am getting mobiles on milepost 60 on the digital signal and at 4 and 5 bars.
code3kid
WA
#3
Have you found what talkgroup thy're using on the DOJ IWN? Whiskey (site 36) is probably the closest site.
SkyOtaku
#4
Here are the only DOJ IWN sites and talkgroups I am getting:
D4 Colfax Area -- Schrag WA, Mica Peak
D6 Ephrata Area -- Mount Spokane, Whiskey Dick, Beezley
D6 Dispatch A09 -- Whiskey Dick, Mount Spokane
D3 Union Gap Area -- Whiskey Dick, Mount Spokane
Although I am getting many more under the conventional system. I will plug the sound into ProScan so it can also record to see if D6 Dispatch A09 is the Ellensburg site.
Melmac
#5
A09 was heard in/near Cle Elum, but not ellensburg. it was portable though, so it may be a reception issue as opposed to a usage issue. D6 is the WORST area in terms of coverage, due to the varying terrain.
kd7kdc
Banned
#7
The Mount Spokane control channel frequency must be reused on another hilltop closer to central Washington because there is no District 6 traffic or affiliations on the site looking at it with unitrunker from the Spokane area.
kd7kdc
Banned
#8
Will it's a name tag I made up for the unknown channel names i.e. 59609 is District 6 Area 09
SkyOtaku
#9
Yes its the same as Whisky Dick site. Its one of the group of sites I use to monitor DOJ IWIN.
