WSP Waukesha post
pngoat
Madison, Wisconsin
#1
I am able to pick up the WSP Deforest, and, Tomah posts from the Deerfield, Baraboo, Blue Mound, and, the Milton towers as I am within range of these towers. I can also pick them up on Madison 800, and Madison VH. One day I programed in the frequencies for the Delafield tower,and, the TG for the WSP Waukesha post. (121). To my surprise I could pick them up even though I am well out of range of the Delafield tower. (About 60 miles). My setup is this: Attic mounted RS 20-176 antenna with a Scanner master 137-174 pre-amp mounted at the antenna base. About 75 ft. of RG-8 coax going to a PRO-652. My question is this: Why am I able to pick the Delafield tower when I am so far out of range of the Delafield tower? I can also pick up the Waukesha post on Madison 800, and, Madison VH. I admit that I am no electronic, or, radio expert. The received signal, from the Delafield tower, Madison 800, and Madison VH is strong and clear. Just curious If anyone knows why I can pick up the Delafield tower when I am so far out of range. Any help appreciated. Thank you.
#2
It isn't RF magic...it's wide area trunking magic.
The talkgroup in question is either being asked to be pushed out on a local site due to affiliation, or the system admin has forced a talkgroup to be pushed out to X sites.
Also keep in mind that system control/voice channels are reused a few times in the state. I think there is a Rome channel that is also a Madison VH channel, so my 668 shows the wrong site name from time to time. No big deal.
#3
While the scenario R8000 mentions is likely, WISCOM is a VHF system, and there's plenty of skip on VHF (not really a good thing).
In fact, there's a bunch going on right now:
VHF Propagation Map
Zoom in on Wisconsin; you can click the "blobs" to see the propagation paths.
