WTB : BNC Antenna Switch
TedWCM
Putnam County, NY
I have looked all over internet for a 2 or 3 antenna switch to install in a vehicle.
All of the BNC switches I find are way to big .
Can anyone point me in a direction for a small switch ???
toastycookies
the far east
Like this one?
MCA202M
Receiver Multicouplers, Passive and Active, HF to VHF/UHF
MCA204M is an active multicoupler designed to distribute VHF/UHF antenna signals to four receivers without loss and with high isolation between ports. It is specifically suited for signal intercept stations, both fixed or mobile platforms. It can be used in any VHF/UHF monitoring post using receivers, scanners or spectrum analyzers. The MCA204M has a mechanical and electrical design construction that will meet any government, military or commercial specification. This unit is designed to give high performance results in any radio monitoring post using multiple intercept receivers. Rugged die-cast aluminum enclosure with a black powder coat finish is standard, olive-drab green (MIl-841OD) is also available on request.
If only two (2) output ports are needed model MCA202M is available. This unit have the same specifications as the MCA204M and in the same case style..
TedWCM
Putnam County, NY
Toastycookies thanks , but I just need a simple switch , where I can manually switch which antenna I want to use on 1 radio
Anyone else ??
prcguy
I have some BNC and N type switches which are tiny little machined boxes with a toggle switch made by Sage Laboratories. Not sure where you would find them but you can easily get very small RF relays good to several GHz with BNCs on Ebay for probably $10 and wire up a remote switch to feed the relay 12v to switch your scanners.
prcguy
Anyone else ??
