WX alert. How to program it in with Freescan?
CA
#1
I have the SAME number for my county. The input fields are:
SAME Group Name
FIPS1
FIPS2
FIPS3
Also do you check any of the 3 boxes? Weather alert, attenuater, record?
Delay. 1 to 5?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
#3
It should be pretty simple - I think you would put your SAME code in the FIPS column, give that group a name, and set weather priority alert on. I don't think you'd want the attenuator, and I'm not sure you'd want any delay.
I'd read up on the function in the Easier to Read guides for functions. Assaf? Did I get that right?
Mike
