x2-TDMA -xx or -fx
737mech
Clark County, NV.
Just asking if this is correct, the txt file for help and options for DSD1.6 has -xx expect non-inverted x2-TDMA and -fx decode only X2-TDMA. So am I reading this right that makes a normal X2-TDMA inverted and then the other option to expect non-inverted? I'm seeing some data bursts as X2-TDMA while using DSD with -xr as well as some small ones that label as nxdn96. One liners only. I'm trying to decode on these I'm wondering if anyone has done any other key combinations to decode X2-TDMA? For example should I also be adding the -mg or -mc?
